[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/gets.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 11 22:02:21 EST 2007
Hello glynn,
ANALYSIS
lib/gis/gets.c functions
G_gets (Begins at: 38 Ends at: 73)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 36 | | OK |
metrics are OK
catch_ctrlz (Begins at: 75 Ends at: 93)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
catch_int (Begins at: 95 Ends at: 97)
CalledNBR: | 0 | | OK |
LOC: | 3 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
