[GRASS-QA] GRASS QA: glynn | ./grass6/lib/proj/get_proj.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 11 22:02:34 EST 2007
Hello glynn,
ANALYSIS
lib/proj/get_proj.c functions
pj_get_kv (Begins at: 61 Ends at: 241)
Complexity: | 23 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 71 | ** | Warning |
LOC: | 181 | * | |
at least 1 values are close to an outlier please consider revising code
alloc_options (Begins at: 243 Ends at: 252)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 10 | | OK |
metrics are OK
pj_get_string (Begins at: 254 Ends at: 350)
Complexity: | 13 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 97 | | OK |
metrics are OK
GPJ_get_equivalent_latlong (Begins at: 352 Ends at: 361)
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
set_proj_lib (Begins at: 366 Ends at: 394)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 29 | | OK |
metrics are OK
pj_print_proj_params (Begins at: 396 Ends at: 423)
Complexity: | 5 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
