[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.drain/main.c |no clones | 2 monsters | 0 warnings
Mon Nov 12 10:36:18 EST 2007
Hello carlos,
ANALYSIS
raster/r.drain/main.c functions
main (Begins at: 68 Ends at: 445)
Complexity:   |      33 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |     124 |   *** | MONSTER |
LOC:          |     378 |   *** | MONSTER |
2 metric are OUT OF RANGE!
drain (Begins at: 447 Ends at: 504)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
