[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/r_vpoints.c |no clones | 0 monsters | 3 warnings
Tue Nov 13 20:53:26 EST 2007
Hello hamish,
ANALYSIS
ps/ps.map/r_vpoints.c functions
read_vpoints (Begins at: 42 Ends at: 301)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      80 |    ** | Warning |
LOC:          |     260 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
