[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/ps_vareas.c |no clones | 0 monsters | 0 warnings
Tue Nov 13 07:07:37 EST 2007
Hello hamish,
ANALYSIS
ps/ps.map/ps_vareas.c functions
construct_path (Begins at: 18 Ends at: 58)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
plot_area (Begins at: 61 Ends at: 89)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
set_ps_color_rgbcol_varea (Begins at: 92 Ends at: 131)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
PS_vareas_plot (Begins at: 134 Ends at: 265)
Complexity:   |      17 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |     132 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
