[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/ps_vpoints.c |no clones | 1 monsters | 0 warnings
Tue Nov 13 07:27:19 EST 2007
Hello hamish,
ANALYSIS
ps/ps.map/ps_vpoints.c functions
PS_vpoints_plot (Begins at: 18 Ends at: 265)
Complexity:   |      38 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     248 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
