[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/getl.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 23 08:22:20 EST 2007
Hello markus,
ANALYSIS
lib/gis/getl.c functions
G_getl (Begins at: 17 Ends at: 50)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 34 | | OK |
metrics are OK
G_getl2 (Begins at: 52 Ends at: 86)
Complexity: | 8 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 35 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
