[GRASS-QA] GRASS QA: moritz | ./grass6/imagery/i.find/main.c |no clones | 0 monsters | 0 warnings
Fri Nov 23 16:15:29 EST 2007
Hello moritz,
ANALYSIS
imagery/i.find/main.c functions
main (Begins at: 56 Ends at: 101)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
find (Begins at: 104 Ends at: 152)
Complexity:   |       7 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
