[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/sqlite/index.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Nov 24 07:58:55 EST 2007
Hello markus,
ANALYSIS
db/drivers/sqlite/index.c functions
db__driver_create_index (Begins at: 29 Ends at: 95)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 38 | * | |
LOC: | 67 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
