[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/postgres/describe.c |no clones | 0 monsters | 0 warnings
Sat Nov 24 08:23:04 EST 2007
Hello markus,
ANALYSIS
db/drivers/postgres/describe.c functions
db__driver_describe_table (Begins at: 7 Ends at: 39)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
describe_table (Begins at: 42 Ends at: 159)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |     118 |       |      OK |
metrics are OK
get_column_info (Begins at: 161 Ends at: 225)
Complexity:   |      20 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
get_gpg_type (Begins at: 228 Ends at: 237)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
