[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.out.mpeg/main.c |no clones | 0 monsters | 1 warnings
Tue Nov 27 13:41:12 EST 2007
Hello carlos,
ANALYSIS
raster/r.out.mpeg/main.c functions
main (Begins at: 73 Ends at: 151)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
load_files (Begins at: 154 Ends at: 304)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      46 |     * |         |
LOC:          |     151 |     * |         |
metrics are OK
use_r_out (Begins at: 307 Ends at: 325)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
gee_wildfiles (Begins at: 329 Ends at: 381)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
parse_command (Begins at: 385 Ends at: 486)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      27 |       |      OK |
LOC:          |     102 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
