[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.region/main.c |no clones | 3 monsters | 0 warnings
Wed Nov 28 13:37:02 EST 2007
Hello carlos,
ANALYSIS
raster/r.region/main.c functions
main (Begins at: 26 Ends at: 377)
Complexity:   |      58 |   *** | MONSTER |
CalledNBR:    |     118 |   *** | MONSTER |
LOC:          |     352 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 379 Ends at: 382)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
nsew (Begins at: 384 Ends at: 390)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 392 Ends at: 400)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-28 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
