[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.series/main.c |1 clones ( main.c )| 0 monsters | 0 warnings
Wed Nov 28 19:56:10 EST 2007
Hello glynn,
ANALYSIS
raster/r.series/main.c functions
build_method_list (Begins at: 57 Ends at: 74)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
main (Begins at: 76 Ends at: 239)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      55 |     * |         |
LOC:          |     164 |     * |         |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  build_method_list
In raster/r.series/main.c clones of  build_method_list are:
	raster/r.resamp.stats/main.c  build_method_list
Threshold GRASS6 key metrics values at 2007-11-28 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
