[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/parser.c |no clones | 3 monsters | 4 warnings
Thu Nov 29 08:47:59 EST 2007
Hello markus,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 162 Ends at: 183)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 186 Ends at: 244)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 247 Ends at: 329)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 332 Ends at: 627)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |      39 |     * |         |
LOC:          |     296 |   *** | MONSTER |
1 metric are OUT OF RANGE!
G_define_module (Begins at: 630 Ends at: 682)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 684 Ends at: 953)
Complexity:   |      38 |   *** | MONSTER |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     270 |    ** | Warning |
uses_new_gisprompt (Begins at: 956 Ends at: 1006)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 1008 Ends at: 1194)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     187 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1196 Ends at: 1212)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
print_escaped_for_html (Begins at: 1219 Ends at: 1230)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1233 Ends at: 1447)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     215 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1449 Ends at: 1674)
Complexity:   |      42 |   *** | MONSTER |
CalledNBR:    |      85 |    ** | Warning |
LOC:          |     226 |    ** | Warning |
G_script (Begins at: 1676 Ends at: 1787)
Complexity:   |      22 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1789 Ends at: 1884)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      96 |       |      OK |
metrics are OK
G_gui_tcltk (Begins at: 1887 Ends at: 1916)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_gui_wx (Begins at: 1919 Ends at: 1930)
LOC:          |      12 |       |      OK |
metrics are OK
G_gui (Begins at: 1933 Ends at: 1941)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1944 Ends at: 1959)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1961 Ends at: 1991)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
show (Begins at: 1993 Ends at: 2006)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 2008 Ends at: 2035)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 2040 Ends at: 2049)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 2051 Ends at: 2111)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 2113 Ends at: 2150)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 2152 Ends at: 2194)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2196 Ends at: 2262)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2264 Ends at: 2304)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2306 Ends at: 2333)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2335 Ends at: 2358)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2360 Ends at: 2423)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2425 Ends at: 2463)
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2466 Ends at: 2522)
Complexity:   |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2524 Ends at: 2552)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2554 Ends at: 2562)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2564 Ends at: 2654)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2656 Ends at: 2686)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2688 Ends at: 2745)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2747 Ends at: 2849)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
