[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.support/front/run.c |no clones | 0 monsters | 0 warnings
Mon Oct 1 05:24:59 EDT 2007
Hello glynn,
ANALYSIS
raster/r.support/front/run.c functions
run_etc_support (Begins at: 12 Ends at: 23)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
run_system (Begins at: 31 Ends at: 39)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
