[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.save/main.c |no clones | 2 monsters | 0 warnings
Mon Oct 1 10:47:16 EDT 2007
Hello carlos,
ANALYSIS
display/d.save/main.c functions
main (Begins at: 50 Ends at: 375)
Complexity:   |      38 |   *** | MONSTER |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     326 |   *** | MONSTER |
2 metric are OUT OF RANGE!
in_frame_list (Begins at: 379 Ends at: 387)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
init_globals (Begins at: 390 Ends at: 403)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
which_item (Begins at: 429 Ends at: 437)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
set_item (Begins at: 441 Ends at: 495)
Complexity:   |      16 |     * |         |
CalledNBR:    |      21 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
process_list (Begins at: 499 Ends at: 530)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
process_items (Begins at: 535 Ends at: 557)
CalledNBR:    |       6 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
process_pad (Begins at: 561 Ends at: 574)
CalledNBR:    |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
