[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.flow/io.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Oct 2 11:06:03 EDT 2007
Hello carlos,
ANALYSIS
raster/r.flow/io.c functions
tmp_name (Begins at: 42 Ends at: 55)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
open_existing_cell_file (Begins at: 60 Ends at: 71)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 12 | | OK |
metrics are OK
read_input_files (Begins at: 74 Ends at: 135)
Complexity: | 10 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 62 | | OK |
metrics are OK
open_segment_file (Begins at: 138 Ends at: 165)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 28 | | OK |
metrics are OK
open_output_files (Begins at: 168 Ends at: 183)
Complexity: | 5 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 16 | | OK |
metrics are OK
close_files (Begins at: 186 Ends at: 201)
CalledNBR: | 5 | | OK |
LOC: | 16 | | OK |
metrics are OK
write_density_file (Begins at: 204 Ends at: 242)
CalledNBR: | 26 | | OK |
LOC: | 39 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
