[GRASS-QA] GRASS QA: carlos | ./grass6/ps/ps.map/outl_io.c |no clones | 0 monsters | 0 warnings
Tue Oct 2 11:06:03 EDT 2007
Hello carlos,
ANALYSIS
ps/ps.map/outl_io.c functions
o_io_init (Begins at: 17 Ends at: 24)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
o_read_row (Begins at: 26 Ends at: 57)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
blank_line (Begins at: 59 Ends at: 64)
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
o_open_file (Begins at: 66 Ends at: 87)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
o_close_file (Begins at: 89 Ends at: 94)
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
