[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.random/count.c |2
clones ( count.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 3 14:00:31 EDT 2007
Hello carlos,
ANALYSIS
raster/r.random/count.c functions
get_stats (Begins at: 18 Ends at: 85)
Complexity: | 9 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 68 | | OK |
metrics are OK
set_min (Begins at: 88 Ends at: 114)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 27 | | OK |
metrics are OK
set_max (Begins at: 117 Ends at: 143)
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
set_max set_min
In raster/r.random/count.c clones of set_max are:
raster/r.random/count.c set_min
In raster/r.random/count.c clones of set_min are:
raster/r.random/count.c set_max
Threshold GRASS6 key metrics values at 2007-10-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
