[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/move.c |no clones | 0 monsters | 0 warnings
Mon Oct 8 05:34:34 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/move.c functions
do_move (Begins at: 28 Ends at: 84)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
