[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/break.c |no clones | 0 monsters | 1 warnings
Mon Oct 8 05:34:32 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/break.c functions
do_break (Begins at: 30 Ends at: 156)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      31 |       |      OK |
LOC:          |     127 |     * |         |
at least 1 values are close to an outlier please consider revising code
do_connect (Begins at: 158 Ends at: 348)
Complexity:   |      20 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      46 |     * |         |
LOC:          |     191 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
