[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/open.c |no clones | 1 monsters | 0 warnings
Tue Oct 9 11:01:53 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/open.c functions
open_old_dummy (Begins at: 51 Ends at: 51)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
fatal_error (Begins at: 69 Ends at: 106)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Vect_set_open_level (Begins at: 109 Ends at: 137)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Vect__open_old (Begins at: 140 Ends at: 395)
Complexity:   |      31 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |     103 |   *** | MONSTER |
LOC:          |     256 |    ** | Warning |
1 metric are OUT OF RANGE!
Vect_open_old (Begins at: 398 Ends at: 418)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Vect_open_update (Begins at: 421 Ends at: 457)
LOC:          |      37 |       |      OK |
metrics are OK
Vect_open_old_head (Begins at: 460 Ends at: 477)
LOC:          |      18 |       |      OK |
metrics are OK
Vect_open_update_head (Begins at: 480 Ends at: 510)
LOC:          |      31 |       |      OK |
metrics are OK
Vect_open_new (Begins at: 513 Ends at: 594)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |      82 |       |      OK |
metrics are OK
Vect_coor_info (Begins at: 597 Ends at: 643)
CalledNBR:    |       7 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
Vect_maptype_info (Begins at: 646 Ends at: 676)
CalledNBR:    |       4 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Vect_open_topo (Begins at: 679 Ends at: 756)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      78 |       |      OK |
metrics are OK
Vect_open_spatial_index (Begins at: 759 Ends at: 822)
CalledNBR:    |       8 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-09 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
