[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.in.xyz/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 10 03:38:03 EDT 2007
Hello hamish,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 26 Ends at: 629)
Complexity: | 93 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 208 | *** | MONSTER |
LOC: | 604 | *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 633 Ends at: 725)
Complexity: | 17 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 24 | | OK |
LOC: | 93 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
