[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.build.polylines/walk.c |no clones | 0 monsters | 0 warnings
Wed Oct 10 07:56:54 EDT 2007
Hello martinl,
ANALYSIS
vector/v.build.polylines/walk.c functions
find_next_line (Begins at: 11 Ends at: 31)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
walk_back (Begins at: 38 Ends at: 77)
Complexity:   |       5 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
walk_forward_and_pick_up_coords (Begins at: 81 Ends at: 147)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
