[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/args.c |no clones | 1 monsters | 0 warnings
Wed Oct 10 12:56:42 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/args.c functions
parser (Begins at: 3 Ends at: 285)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      79 |    ** | Warning |
LOC:          |     283 |   *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
