[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.in.xyz/support.c |2
clones ( support.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Oct 11 10:06:55 EDT 2007
Hello glynn,
ANALYSIS
raster/r.in.xyz/support.c functions
blank_array (Begins at: 14 Ends at: 48)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 4 | | OK |
LOC: | 35 | | OK |
metrics are OK
update_n (Begins at: 51 Ends at: 63)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 13 | | OK |
metrics are OK
update_min (Begins at: 66 Ends at: 82)
Complexity: | 3 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
update_max (Begins at: 85 Ends at: 102)
LOC: | 18 | | OK |
metrics are OK
update_sum (Begins at: 105 Ends at: 117)
LOC: | 13 | | OK |
metrics are OK
update_sumsq (Begins at: 120 Ends at: 132)
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
update_sumsq update_sum
In raster/r.in.xyz/support.c clones of update_sumsq are:
raster/r.in.xyz/support.c update_sum
In raster/r.in.xyz/support.c clones of update_sum are:
raster/r.in.xyz/support.c update_sumsq
Threshold GRASS6 key metrics values at 2007-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
