[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/break.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Oct 12 08:16:13 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/break.c functions
do_break (Begins at: 30 Ends at: 156)
Complexity: | 10 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 31 | | OK |
LOC: | 127 | * | |
at least 1 values are close to an outlier please consider revising code
do_connect (Begins at: 158 Ends at: 348)
Complexity: | 20 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 46 | * | |
LOC: | 191 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
