[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/select.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Oct 12 08:16:13 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/select.c functions
select_lines (Begins at: 26 Ends at: 89)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 64 | | OK |
metrics are OK
do_print_selected (Begins at: 97 Ends at: 109)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
sel_by_cat (Begins at: 116 Ends at: 162)
Complexity: | 4 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 10 | | OK |
LOC: | 47 | | OK |
metrics are OK
sel_by_coordinates (Begins at: 169 Ends at: 216)
CalledNBR: | 14 | | OK |
LOC: | 48 | | OK |
metrics are OK
sel_by_bbox (Begins at: 223 Ends at: 263)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 9 | | OK |
LOC: | 41 | | OK |
metrics are OK
sel_by_polygon (Begins at: 270 Ends at: 316)
LOC: | 47 | | OK |
metrics are OK
sel_by_id (Begins at: 323 Ends at: 366)
LOC: | 44 | | OK |
metrics are OK
sel_by_where (Begins at: 373 Ends at: 446)
CalledNBR: | 25 | | OK |
LOC: | 74 | | OK |
metrics are OK
merge_lists (Begins at: 449 Ends at: 467)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 19 | | OK |
metrics are OK
reverse_selection (Begins at: 470 Ends at: 488)
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
