[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.segment/main.c |1 clones ( main.c )| 1 monsters | 0 warnings
Sat Oct 13 07:02:23 EDT 2007
Hello martinl,
ANALYSIS
vector/v.segment/main.c functions
main (Begins at: 30 Ends at: 228)
Complexity:   |      23 |     * |         |
CalledNBR:    |      93 |   *** | MONSTER |
LOC:          |     199 |    ** | Warning |
1 metric are OUT OF RANGE!
find_line (Begins at: 233 Ends at: 250)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
offset_pt_90 (Begins at: 256 Ends at: 260)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  find_line
In vector/v.segment/main.c clones of  find_line are:
	vector/v.lrs/v.lrs.segment/main.c  find_line
Threshold GRASS6 key metrics values at 2007-10-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
