[GRASS-QA] GRASS QA: carlos | ./grass6/lib/vector/Vlib/map.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Oct 14 13:10:52 EDT 2007
Hello carlos,
ANALYSIS
lib/vector/Vlib/map.c functions
Vect_copy_map_lines (Begins at: 37 Ends at: 85)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 49 | | OK |
metrics are OK
copy_file (Begins at: 92 Ends at: 132)
Complexity: | 6 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 41 | | OK |
metrics are OK
Vect_copy (Begins at: 135 Ends at: 254)
Complexity: | 13 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 51 | * | |
LOC: | 120 | * | |
metrics are OK
Vect_rename (Begins at: 257 Ends at: 363)
Complexity: | 12 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 44 | * | |
LOC: | 107 | | OK |
metrics are OK
Vect_delete (Begins at: 372 Ends at: 489)
Complexity: | 15 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 55 | * | |
LOC: | 118 | | OK |
metrics are OK
Vect_copy_tables (Begins at: 498 Ends at: 559)
Complexity: | 8 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 62 | | OK |
metrics are OK
Vect_copy_table (Begins at: 562 Ends at: 580)
Complexity: | 1 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
Vect_copy_table_by_cats (Begins at: 583 Ends at: 624)
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 10 | | OK |
LOC: | 42 | | OK |
at least 1 values are close to an outlier please consider revising code
Vect_set_release_support (Begins at: 632 Ends at: 642)
CalledNBR: | 0 | | OK |
LOC: | 11 | | OK |
metrics are OK
Vect_set_category_index_update (Begins at: 645 Ends at: 648)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
