[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/xdrstring.c |no clones | 0 monsters | 0 warnings
Mon Oct 15 02:56:50 EDT 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/xdrstring.c functions
db__send_string_array (Begins at: 7 Ends at: 17)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
db__recv_string_array (Begins at: 21 Ends at: 55)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
db__send_string (Begins at: 58 Ends at: 92)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
db__recv_string (Begins at: 95 Ends at: 122)
Complexity:   |       4 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
db__send_Cstring (Begins at: 125 Ends at: 133)
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
