[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/xdrstring.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 15 03:00:45 EDT 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/xdrstring.c functions
db__send_string_array (Begins at: 7 Ends at: 17)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
db__recv_string_array (Begins at: 21 Ends at: 55)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 35 | | OK |
metrics are OK
db__send_string (Begins at: 58 Ends at: 92)
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 35 | | OK |
metrics are OK
db__recv_string (Begins at: 95 Ends at: 122)
Complexity: | 4 | | OK |
LOC: | 28 | | OK |
metrics are OK
db__send_Cstring (Begins at: 125 Ends at: 133)
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
