[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Driver.c |1 clones ( Driver.c )| 0 monsters | 0 warnings
Tue Oct 16 10:55:36 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Driver.c functions
PNG_Driver (Begins at: 21 Ends at: 64)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  PNG_Driver
In lib/pngdriver/Driver.c clones of  PNG_Driver are:
	lib/psdriver/Driver.c  PS_Driver
Threshold GRASS6 key metrics values at 2007-10-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
