[GRASS-QA] GRASS QA: carlos | ./grass6/ps/ps.map/catval.c |no clones | 0 monsters | 0 warnings
Fri Oct 19 11:54:04 EDT 2007
Hello carlos,
ANALYSIS
ps/ps.map/catval.c functions
load_catval_array_rgb (Begins at: 36 Ends at: 92)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
load_catval_array_size (Begins at: 94 Ends at: 153)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
load_catval_array_rot (Begins at: 155 Ends at: 202)
LOC:          |      48 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
