[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.label/main.c |no clones | 2 monsters | 0 warnings
Fri Oct 19 11:54:04 EDT 2007
Hello carlos,
ANALYSIS
vector/v.label/main.c functions
main (Begins at: 34 Ends at: 408)
Complexity:   |      36 |   *** | MONSTER |
CalledNBR:    |     137 |   *** | MONSTER |
LOC:          |     375 |   *** | MONSTER |
2 metric are OUT OF RANGE!
print_label (Begins at: 410 Ends at: 432)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      17 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
