[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.info/main.c |no clones | 3 monsters | 0 warnings
Sun Oct 21 19:12:50 EDT 2007
Hello brad,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 37 Ends at: 391)
Complexity:   |      42 |   *** | MONSTER |
CalledNBR:    |     144 |   *** | MONSTER |
LOC:          |     355 |   *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 395 Ends at: 399)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
compose_line (Begins at: 402 Ends at: 417)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
