[GRASS-QA] GRASS QA: martinl | ./grass6/general/g.region/cmd/main.c |no clones | 3 monsters | 0 warnings
Mon Oct 22 10:36:01 EDT 2007
Hello martinl,
ANALYSIS
general/g.region/cmd/main.c functions
main (Begins at: 28 Ends at: 865)
Complexity:   |     115 |   *** | MONSTER |
CalledNBR:    |     253 |   *** | MONSTER |
LOC:          |     838 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 867 Ends at: 873)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
nsew (Begins at: 875 Ends at: 881)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 883 Ends at: 891)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
