[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.what.vect/what.c |no clones | 3 monsters | 0 warnings
Mon Oct 22 11:16:33 EDT 2007
Hello carlos,
ANALYSIS
display/d.what.vect/what.c functions
what (Begins at: 18 Ends at: 423)
Complexity:   |      76 |   *** | MONSTER |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |     176 |   *** | MONSTER |
LOC:          |     406 |   *** | MONSTER |
3 metric are OUT OF RANGE!
show_buttons (Begins at: 426 Ends at: 446)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
