[GRASS-QA] GRASS QA: carlos | ./grass6/imagery/i.pca/main.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 22 11:59:15 EDT 2007
Hello carlos,
ANALYSIS
imagery/i.pca/main.c functions
main (Begins at: 43 Ends at: 174)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 49 | * | |
LOC: | 132 | * | |
metrics are OK
round_c (Begins at: 177 Ends at: 189)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
set_output_scale (Begins at: 193 Ends at: 222)
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 30 | | OK |
metrics are OK
calc_mu (Begins at: 226 Ends at: 275)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 50 | | OK |
metrics are OK
calc_covariance (Begins at: 279 Ends at: 344)
Complexity: | 8 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 66 | | OK |
metrics are OK
write_pca (Begins at: 348 Ends at: 516)
Complexity: | 22 | * | |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 51 | * | |
LOC: | 169 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
