[GRASS-QA] GRASS QA: glynn | ./grass6/lib/stats/c_reg.c |2 clones (
c_reg.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Oct 23 08:15:48 EDT 2007
Hello glynn,
ANALYSIS
lib/stats/c_reg.c functions
regression (Begins at: 3 Ends at: 48)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 46 | | OK |
metrics are OK
c_reg_m (Begins at: 50 Ends at: 53)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
c_reg_c (Begins at: 55 Ends at: 58)
LOC: | 4 | | OK |
metrics are OK
regression_w (Begins at: 60 Ends at: 105)
LOC: | 46 | | OK |
metrics are OK
w_reg_m (Begins at: 107 Ends at: 110)
LOC: | 4 | | OK |
metrics are OK
w_reg_c (Begins at: 112 Ends at: 115)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
regression_w regression
In lib/stats/c_reg.c clones of regression_w are:
lib/stats/c_reg.c regression
In lib/stats/c_reg.c clones of regression are:
lib/stats/c_reg.c regression_w
Threshold GRASS6 key metrics values at 2007-10-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
