[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.reclass/main.c |no clones | 3 monsters | 0 warnings
Fri Oct 26 14:49:21 EDT 2007
Hello carlos,
ANALYSIS
vector/v.reclass/main.c functions
cmpcat (Begins at: 29 Ends at: 37)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
main (Begins at: 40 Ends at: 385)
Complexity:   |      40 |   *** | MONSTER |
CalledNBR:    |     149 |   *** | MONSTER |
LOC:          |     346 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
