[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.los/segment.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 27 02:56:57 EDT 2007
Hello hamish,
ANALYSIS
raster/r.los/segment.c functions
segment (Begins at: 17 Ends at: 83)
Complexity: | 5 | | OK |
ParamNBR: | 15 | *** | MONSTER |
CalledNBR: | 2 | | OK |
LOC: | 67 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
