[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.in.xyz/main.c |no clones | 3 monsters | 0 warnings
Tue Oct 30 18:12:24 EDT 2007
Hello markus,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 26 Ends at: 629)
Complexity:   |      93 |   *** | MONSTER |
CalledNBR:    |     208 |   *** | MONSTER |
LOC:          |     604 |   *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 633 Ends at: 725)
Complexity:   |      17 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      24 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
