[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.los/mark_pts.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 31 02:54:04 EDT 2007
Hello hamish,
ANALYSIS
raster/r.los/mark_pts.c functions
mark_visible_points (Begins at: 20 Ends at: 45)
Complexity: | 3 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 2 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-31 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
