[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/list.c |no clones | 0 monsters | 2 warnings
Tue Sep 4 04:46:16 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/list.c functions
G_set_list_hit_return (Begins at: 31 Ends at: 57)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
G_list_element (Begins at: 59 Ends at: 138)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      18 |       |      OK |
LOC:          |      80 |       |      OK |
at least 1 values are close to an outlier please consider revising code
sigpipe_catch (Begins at: 140 Ends at: 144)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
list_element (Begins at: 146 Ends at: 228)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      16 |       |      OK |
LOC:          |      83 |       |      OK |
G_list (Begins at: 230 Ends at: 304)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
G_free_list (Begins at: 306 Ends at: 318)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
