[GRASS-QA] GRASS QA: markus | ./grass6/lib/external/shapelib/shpopen.c |no clones | 5 monsters | 2 warnings
Wed Sep 5 08:00:52 EDT 2007
Hello markus,
ANALYSIS
lib/external/shapelib/shpopen.c functions
cvsid_aw (Begins at: 215 Ends at: 215)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
SwapWord (Begins at: 245 Ends at: 264)
CalledNBR:    |       0 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
SfRealloc (Begins at: 266 Ends at: 280)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
SHPWriteHeader (Begins at: 282 Ends at: 410)
Complexity:   |      18 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     129 |     * |         |
metrics are OK
SHPOpen (Begins at: 413 Ends at: 650)
Complexity:   |      21 |     * |         |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     238 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
SHPClose (Begins at: 659 Ends at: 686)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
SHPGetInfo (Begins at: 695 Ends at: 724)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      30 |       |      OK |
metrics are OK
SHPCreate (Begins at: 727 Ends at: 860)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |     134 |     * |         |
metrics are OK
_SHPSetBounds (Begins at: 862 Ends at: 884)
CalledNBR:    |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
SHPComputeExtents (Begins at: 887 Ends at: 922)
LOC:          |      36 |       |      OK |
metrics are OK
SHPCreateObject (Begins at: 925 Ends at: 1047)
Complexity:   |      10 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      11 |       |      OK |
LOC:          |     123 |     * |         |
1 metric are OUT OF RANGE!
SHPCreateSimpleObject (Begins at: 1050 Ends at: 1064)
LOC:          |      15 |       |      OK |
metrics are OK
SHPWriteObject (Begins at: 1067 Ends at: 1442)
Complexity:   |      47 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      68 |    ** | Warning |
LOC:          |     376 |   *** | MONSTER |
2 metric are OUT OF RANGE!
SHPReadObject (Begins at: 1445 Ends at: 1781)
Complexity:   |      48 |   *** | MONSTER |
CalledNBR:    |      86 |   *** | MONSTER |
LOC:          |     337 |   *** | MONSTER |
SHPTypeName (Begins at: 1788 Ends at: 1838)
Complexity:   |      17 |     * |         |
LOC:          |      51 |       |      OK |
metrics are OK
SHPPartTypeName (Begins at: 1845 Ends at: 1871)
Complexity:   |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
SHPDestroyObject (Begins at: 1878 Ends at: 1906)
Complexity:   |       8 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
SHPRewindObject (Begins at: 1909 Ends at: 2070)
Complexity:   |      12 |       |      OK |
LOC:          |     162 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
