[GRASS-QA] GRASS QA: martinl | ./grass6/db/base/select.c |no clones | 0 monsters | 0 warnings
Sat Sep 8 15:01:41 EDT 2007
Hello martinl,
ANALYSIS
db/base/select.c functions
main (Begins at: 34 Ends at: 88)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
sel (Begins at: 91 Ends at: 164)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
parse_command_line (Begins at: 167 Ends at: 256)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
get_stmt (Begins at: 259 Ends at: 280)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
stmt_is_empty (Begins at: 283 Ends at: 288)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
print_column_definition (Begins at: 291 Ends at: 300)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
