[GRASS-QA] GRASS QA: martinl |
./grass6/vector/v.overlay/line_area.c |no clones | 0 monsters
| 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Sep 12 17:47:55 EDT 2007
Hello martinl,
ANALYSIS
vector/v.overlay/line_area.c functions
point_area (Begins at: 21 Ends at: 46)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 7 | | OK |
LOC: | 26 | | OK |
metrics are OK
line_area (Begins at: 48 Ends at: 230)
Complexity: | 22 | * | |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 55 | * | |
LOC: | 183 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
