[GRASS-QA] GRASS QA: brad | ./grass6/lib/vector/transform/transform.c |2 clones ( transform.c )| 0 monsters | 3 warnings
Wed Sep 19 20:02:14 EDT 2007
Hello brad,
ANALYSIS
lib/vector/transform/transform.c functions
compute_transformation_coef (Begins at: 88 Ends at: 171)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
transform_a_into_b (Begins at: 174 Ends at: 182)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
transform_b_into_a (Begins at: 185 Ends at: 207)
LOC:          |      23 |       |      OK |
metrics are OK
residuals_a_predicts_b (Begins at: 209 Ends at: 219)
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
at least 1 values are close to an outlier please consider revising code
residuals_b_predicts_a (Begins at: 222 Ends at: 241)
LOC:          |      20 |       |      OK |
print_transform_matrix (Begins at: 243 Ends at: 254)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
resid (Begins at: 257 Ends at: 298)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |       4 |       |      OK |
LOC:          |      42 |       |      OK |
Clone analysis:
This file has 2 potentially cloned functions:
  residuals_b_predicts_a  residuals_a_predicts_b
In lib/vector/transform/transform.c clones of  residuals_a_predicts_b are:
	lib/vector/transform/transform.c  residuals_b_predicts_a
In lib/vector/transform/transform.c clones of  residuals_b_predicts_a are:
	lib/vector/transform/transform.c  residuals_a_predicts_b
Threshold GRASS6 key metrics values at 2007-09-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
