[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.to.rast/vect2rast.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 21 17:39:35 EDT 2007
Hello carlos,
ANALYSIS
vector/v.to.rast/vect2rast.c functions
vect_to_rast (Begins at: 9 Ends at: 213)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 74 | ** | Warning |
LOC: | 205 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
